  • 9
Kappa0698
Roaming headache!
Hi!
I am away in Spain, have been trying to activate my roaming through the Mobile portal but it keeps failing to activate. I slide the slider and it keeps switching back to off!
My number is **************.
Many Thanks
Tom
Tags (1)
  • 3.83K
  • 901
  • 1.7K
Re: Roaming headache!
Hi Tom,
are you able to use another phone to call the Virgin mobile UK support line: +447953 967 967
Ask them activate roaming for you and also check that International call barring is off.
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 9
Kappa0698
Hi Alex,
Unfortunately not! Neither mine or my Wife's phones are set up for roaming, yes we are idiots!
Tom
