  • 7
clawberry
Message 1 of 10
ROAMING - Need help.......I am an amateur
On 4th February I am flying to Malaysia (Kuala Lumpur) to stay with my son and his family.  I am looking at all the nightmares people have with ROAMING.
Once off the plane, I am making my way by train to central Kualar Lumpur then getting a taxi to my son's place (Have refused his offer of being picked up at the airport because he has a pregnant wife and a baby at home)
My Roaming must work as I need to contact him when I arrive at his building as there is no security and no way to access the building without a phone call to him!
How can I check that my mobile will work????
Kind regards
Jane
Helpful Answers
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 4 of 10
Re: ROAMING - Need help.......I am an amateur
Hi clawberry
Your certainly not being silly Smiley Happy
You would only have to setup roaming once or activate this as once its active then its permanently on unless you request to turn it off
you can also activate this from your online account
Have I answered your question today? Mark the question as resolved if so!
Mark as helpful answer if this has helped you to show other members the resolution
Virgin Mobile Staff , However, All opinions are my own
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 8 of 10
it should indeed because the number should be saved already as the + format
the charges are the following
Making a Call £2.00 (per minute)
Recieving a Call £1.00 (per minute)
Sending an SMS 30p
Sending an MMS 40p
Data £5.00 (per MB)
The networks you can connect to are Smiley Happy
CELCOM
DiGi
Maxis Mobile
All Replies
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 2 of 10
you can follow this thread Smiley Happy
Roaming Setup
  • 7
clawberry
Message 3 of 10
Can I set it up before I set off?  Or am I being silly ?(as usual)
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 4 of 10
Hi clawberry
  • 7
clawberry
Message 5 of 10
Done it!!!! This will definitely work then???? When I am there, I just dial the number in my mobile don't I? I don't need a country code? How can I find out charges of texts and calls? questions questions.....sorry
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 6 of 10
Excellent Smiley Very Happy now time for your jolly hols!
When u leave the UK, switch the phone off. When you land on the ground then you switch the phone back on
it should connect to the partner network in Malaysia . To dial back to the UK you need to drop the 0 from the 07 , 01 , 02 or 03 or change to
+447 , +441 , +442 or +443 then the rest of the number
if you can find the + then you can change to 00447 , 00441 ,00442 or 00443
  • 7
clawberry
Message 7 of 10
Thank you!   One more little question.  My son has a Malaysian mobile number and it is in my phone.  It should go straight through?  As I am on a contract I presume I will be stung a high charge for a call or text?
Jeez, what a numpty I am!
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 8 of 10
Sending an SMS 30p
Sending an MMS 40p
Data £5.00 (per MB)
CELCOM
DiGi
Maxis Mobile
  • 7
clawberry
Message 9 of 10
Thank you x
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 10 of 10
its my pleasure Smiley Happy
