  • 5
neil50
Problems with mobiledata in europe
I have travelled to Belgium from the Uk. I've set up data roaming for my phone and purchased a data package and had that confirmed. However i cannot access mobile internet.  Can anyone suggest a solution? Thanks
  • 45
stazi
Re: Problems with mobiledata in europe
I had the same problem- bought an EU travel pass, always had roaming on my account- but after the VM account upgrade in March my account DIDN'T have roaming activated- even though my account said it was!!
Only option is 789 to VM CS get them to activate roaming
  • 5
neil50
Thanks for your prompt reply. I've spoken to VM CS twice. They assure me everything is okay with my roaming and data package. I was told that if it still didn't work there wad nothing else they could do! Exactly the same problem with my wife's phone as well. I've just paid £40 pounds on 2 data packages but have had to buy internet use from the campsite! I'm not sure how much the calls to CS are from Belgium either!
