Jonlong
Phone doesn't work in Spain.
I have 2 Virgin phones. I phoned Virgin on Friday 17th June to tell them i was going to Spain and I wanted to use my phones abroad. I was told they will work fine. They do not work. I cannot phone, text of use data. Very dissatisfied with Virgin over this and will be seeking compensation when I return and closing my account.
  • 6.82K
  • 217
  • 508
Re: Phone doesn't work in Spain.
Hi Jonlong,
Welcome to the Community Forum, I'm sorry that you aren't able to use your Virgin mobiles while abroad in Spain. Apologies as well for the delay in getting back to you. Have you checked that the phones are set for roaming?
For further help with this, please see the following post: Roaming.
If you have already done the things on this post and can't use your phones abroad, I can look into this further for you. I'll send you a private message requesting further details. Just check the purple envelope at the top right of this page.
Kind regards,
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
