kjpollard
Just joined
POOR OR NO SIGNAL
Getting a very pore reception from my mobile getting no signal or just 1 bar thinking of leaving our family as 3 mobiles with virgin they will be loosing over £60 per month if it's not sorted
Borab00m
Re: POOR OR NO SIGNAL
We also have a bad signal in our area .Never use mobile to make calls because of it .kind of defeats the object of having one !!
  • 3.83K
  • 900
  • 1.7K
Hi kjpollard,
have you contacted the Virgin mobile team on 789 from your Virgin mobile or 0345 6000 789 from any other phone to report this problem?
It may just be due to a local area fault or maintanance which will hopefully soon be rectified.
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
