  • 242
  • 15
  • 55
steelysteph
Superfast
Original Nokia 3310 - will it work?
Hi folks, not VM specific this is an all networks query.
Following all the hype with the launch of the new Nokia 3310 I dug out my original model and it still powers up.  I have an old EE 3G sim card but that didn't work, of course that might be because it hasn't been topped up in a while.  Before I top up, or buy another, I have 2 questions.
  1. Will a 3G sim work in an old 2G phone?
  2. If I end up getting a 2G sim from Ebay will it work on modern networks?
  • 1.22K
  • 52
  • 172
jpeg1
Knows their stuff
Re: Original Nokia 3310 - will it work?
1. Yes, but it might be a different physical size, so you would need an adaptor to fit the SIM in a bigger slot.
2. It might, but personally I wouldn't risk it.
  • 4.04K
  • 941
  • 1.78K
Hi steelysteph,
yes SIM's are backwards compatible so a new SIM will work in an old phone.
(Three Mobile being the exception).
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
