123amo456
Message 1 of 5
Not able to make calls - engaged tone
Unable to make calls - keep getting engaged tone. Tried several numbers. Using iPhone 6. Also I have no voicemail but Virgin have checked it is set up - might be under settings on my phone, but cannot work it out? (Worked fine with my previous iPhone 4s but never with my iPhone 6 which I have had since start of december
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 2 of 5
Re: Not able to make calls - engaged tone
HI 123amo456
Is it just phone calls?
are you able to send and receive SMS?
Have I answered your question today? Mark the question as resolved if so!
Mark as helpful answer if this has helped you to show other members the resolution
Virgin Mobile Staff , However, All opinions are my own
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 3 of 5
123amo456
I have just had an update about this. This is more than likely NOT just you. Some other customers have reported issues too.
The Virgin team are working as hard as they can to resolve this.
  • 221
elvedhel
Message 4 of 5
same issue here.. but oddly only to landlines
tried calling our own home phone ( which tested and is working ) from both mine and my wifes mobile and beeps twice then goes off, and also same when calling in laws ( who are in somerset, we are in Croydon ) and exact same issue. so can only assume its a network issue and not localized
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 5 of 5
HI elvedhel
A few people have reported this issue to various networks and landlines also.
Im sorry for any inconvenience caused , The Virgin team are working on this as we speak
