Bryn70
No signal
signal has been dropping for me and my partner since about 4pm today . i wouldnt mind if this was a one off but it is happening more and more frequently . the postcode area is nr3 2qb . anyone know of any issues in this area ?
  • 3.82K
  • 896
  • 1.7K
Re: No signal
Hi Bryn70,
according to the Mobile Coverage Checker you have excellent 2G & 3G signal.
There may be a local area fault which is hopefully being attended to.
If you want to check on this you need to give Virgin mobile customer services a call on 789 from your Virgin mobile or 0345 6000 789 from any other phone..
AlexKid :-)
____________________________________________________________________
If you want to say thanks > click 'Kudos'.
If this has helped answer your question > click 'Helpful Answer' also.
Bryn70
Re: No signal
I know that according to the signal checker that it should be strong here but yet again we both lost signal this morning for about an hour . There must be another reason for this area
  • 8.26K
  • 236
  • 340
Forum Team (Retired) Mat_H
Re: No signal
HI Bryn70,W
Welcome to the forums Smiley Happy I want to get to the bottom of the signal issues for you.
I've run some checks on my side and I can see there's been a fault on a local mast in the past 3 days.
This should now be resolved for you.
Are you able to let me know how everything is looking for you currently?
Mat
