  • 28
Su123
No signal
Once again I can only make emergency calls, is there a way I can find out if the local Nast is down?
this has been like thus all week, indoors and out.
post code PO11
Helpful Answers
  • 3.82K
  • 895
  • 1.7K
Re: No signal
Hi su123,
you could call Virgin mobile customer services on 0345 6000 789 from another phone. Tell them of your problem & ask if it is due to an area fault.
Hopefully you'll be up & running again very shortly.
AlexKid :-)
_____________________________________________________________________
If you want to say thanks > click 'Kudos'.
If this has helped answer your question > click 'Helpful Answer' also.
All Replies
  • 3.82K
  • 895
  • 1.7K
Re: No signal
Hi su123,
AlexKid :-)
  • 28
Su123
Re: No signal
Thanks, hoped there was a way online to do this.
