CheesyBit
No signal in cyprus
We are in Cyprus, we have 2 virgin mobile SIMs and a Three SIM. Neither Virgin SIM can get a signal. Have roaming activated and it has been for over 15 years with virgin. Never had roaming problems before. I called support from Three phone, they said would reset our SIMs, 12 hours ago. Still no signal. I have wifi, but any attempt to contact virgin via chat failed due to stupid captcha not working. They do not have email contact. VERY VERY DISAPPOINTED. I will likely switch to 3 when we get back.
Tags (1)
  • 3.83K
  • 901
  • 1.7K
Re: No signal in cyprus
Hi CheesyBit,
there is a known network issue with roaming at the moment.
The "Sticky" at the top of these forum posts: Issues with Roaming in the EU
They are working to fix it. Periodically switch flight mode or your phone off/on again in order for it to search and hopefully connect to an available partner network as the problem becomes resolved.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
CheesyBit
Virgin support did not mention it when I called this morning. Still no signal...
