  • 13
kpsandown
No data connection in Portugal
Had roaming set and bought data pack. No connection! Tried 789 always "no answer". Other SIM connects data ok so not phone. Not happy, what now?
Gazzma
Re: No data connection in Portugal
Kp,
Virgin travel passes dont work in Portugal, they dont tell you that though, 3 times I have purchased travel passes and none have worked, they will happily let you call them and run up a bill to try and sort it out, without results, its a con......good luck,
  • 13
kpsandown
Hi Gazzma
Actually got it going. You need a new APN for Virgin. Once set up all ok.
http://www.geeksquad.co.uk/articles/virgin-apn-settings#Virgin%20Android%20APN
