  • 8
mariecardus
Network does not exist
I cannot use my phone as this message keeps coming up with network does not exist
Helpful Answers
  • 3.82K
  • 895
  • 1.7K
Re: Network does not exist
Hi mariecardus,
from your previous post I take it you are a pay monthly customer.
Is this correct and is your account up to date?
If so have you tried turning your phone off & on again or "Airplane mode"  on & off. This should make it search for a network.
If the battery is removable you could also try taking it out whilst the phone is turned on, then replace it & turn the phone back on, This will reboot the phone.
Are you able to go into the phone settings & manually select a network?
If none of the above work you could also try taking the SIM card out (maybe give the gold bit a gentle wipe) then install it again and turn on the phone.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
All Replies
  • 3.82K
  • 895
  • 1.7K
Hi mariecardus,
AlexKid :-)
