  • 8
Hutchinsonp2
Network connection
My Nokia Lumia Windows phone will not connect to the virgin media mobile network. I have just returned from Portugal where it was working fine. I set it to flight mode coming back and it will not now connect.
Helpful Answers
  • 3.82K
  • 897
  • 1.7K
Re: Network connection
Hi Hutchinsonp2,
try turning flight mode off and on again.
If the phone doesn't connect to the Virgin Mobile network itself. Go to settings and do a manual search for networks:
Settings > mobile+SIM > SIM settings > Network selection > search for networks
If it finds Virgin, select it.
Let us know how you get on.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
All Replies
  • 3.82K
  • 897
  • 1.7K
Hi Hutchinsonp2,
AlexKid :-)
  • 8
Hutchinsonp2
Thanks. I did a manual network search on sim settings and virgin came up marked as 'forbidden'. So I did a second manual search and the stupid thing connected. Problem solved (I think). Thanks again.
  • 3.82K
  • 897
  • 1.7K
Hi Hutchinsonp2,
you're welcome Smiley Happy
AlexKid :-)
