  • 5
Mark221
Message 1 of 5
My home screen in my mobile was replaced
I got a new mobile and bought a new Virgin sim card. I cannot remember from when, my home screen was replaced. Now it looks like this:
Virgin
19:57
TUESDAY,31 JANUARY
Did you just sign in?
Update Google Play services
Recommended recent uploads
System update is ready
At the bottom, I found a lock icon with "Swipe up to unlock"
How can I stop that??
Helpful Answers
  • 4.03K
  • 941
  • 1.78K
Message 2 of 5
Re: My home screen in my mobile was replaced
Hi Mark221,
what you are seeing sound like the sort of notifications that appear on all smartphones from time to time.
I would "Swipe up to unlock" your phone, then:
If you have a WiFi connection, perform a system update as it is telling you that one is available. (It can require a fair bit of mobile data which is why I advise doing so over WiFi).
Then you could sign into Google and update Play services.
You can select / customise your prefered home screen from your phone's settings.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
All Replies
  • 4.03K
  • 941
  • 1.78K
Message 2 of 5
Hi Mark221,
AlexKid :-)
  • 5
Mark221
Message 3 of 5
AlexKid,
Thanks alot for your great advice!
Can you tell me (a new user) how to customise my prefered home screen from my phone's settings?
  • 4.03K
  • 941
  • 1.78K
Message 4 of 5
Hi Mark221,
it would be a great help if you said what make and model of phone you have.
AlexKid :-)
  • 5
Mark221
Message 5 of 5
I think It would be better to ask the mobile company.
Thanks a lot again for your helps!
