Phillips61
My and my wife's modiles are not working in Europe despite what 789 said. Any reason .
I am now in Europe for second time in month.  My mobile is not working - has no service.  This despite a call yo operator and checking with 789.  My wife' mobile is not workin either. Why? It seems impossible to contact Virgin by any other means than by this message board!
  • 3.84K
  • 902
  • 1.7K
Re: My and my wife's modiles are not working in Europe despite what 789 said. Any reason .
Hi Phillips61,
log into your account > click on  the "Plan and device" tab.
Go to "Manage my services" > check that "Roaming" is set to ON & "International call barring" is set to OFF
If not, make it so by moving the "switch".
Allow time for your account to update if you have to make a change to the settings.
(Virgin advise that this may take upto 24 hours but fortunately is usually much quicker).
Then reboot your phone by turning it off & on again.
You may have to go into the phone's settings and "manually search for network"
If you are still struggling you may be able to contact here: Help and Support - Contact Us > Mobile > Mobile not working > Chat online.
The advisors are often busy though so you may not get connected straight away.
Alternatively, if you can borrow a phone to call Virgin Mobile. Their UK support line number is: +447953 967 967
Or just post back on this forum Smiley Happy
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
