  • 7
FTGowen
Multiple (daily) incoming calls from an 0844 number
Daily unwanted (spam?) calls from 0844 337 3010 are being received by the mobile use by my daughter. She has not accepted or responded to them. Can they be "blocked" because after a week of this happening it's becoming a nuisance!
  • 3.82K
  • 897
  • 1.7K
Re: Multiple (daily) incoming calls from an 0844 number
Hi FTGowen,
you don't say what phone your daughter has. Some have a "call blocker" built in.
I have an android device and I downloaded a free app from the Play Store called "Calls Blacklist"
(there are others but I find this simple and effective).
It's great for blocking all sorts of telesales/marketing calls.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
