jellybell86
Mobile data not working
Had my old number transferred over via PAC code 12am on Wednesday since then I cannot connect to the Internet using my mobile data. Was able to connect before the completed transfer. Only had phone 8 days. Any ideas?
  • 3.84K
  • 902
  • 1.7K
Re: Mobile data not working
Hi jellybell86,
I think you would be best to call customer services about this (789 free from your mobile).
They will be able to look at your account and check that your mobile data is active since your number port.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 6.86K
  • 218
  • 511
Hi jellybell86,
Welcome to the Community Forum, thanks for posting. I'm sorry that you’re not able to connect to your mobile internet.
Has this been sorted out for you? If you are still having problems, please let me know. I'll need to verify your details in order to look into this, so I'll send you a private message requesting more information. Just check the envelope icon at the top right of this screen.
Kind regards,
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
