  • 242
  • 28
norskyorkie
Up to speed
Mobile TV Anywhere app problem.
Samsung Galaxy S3 Mini
TV Anytime worked OK until today when I was told an update was available, phone is set not to auto update, after several tries and re-starts I got an unable to install message.
I removed it and went to the app store to try again, it still wouldn't install so now I can't use it at all.
Comments please.
  • 8.26K
  • 236
  • 340
Forum Team (Retired) Mat_H
Re: Mobile TV Anywhere app problem.
Hi norsyorkie,
I'm really sorry that you're having some issues with TV anywhere. I want to get this all sorted for you.
Can you let me know what happens when you try and re-download the app? What error message do you get?
Let me know as soon as you can.
Mat
  • 242
  • 28
norskyorkie
Up to speed
The download seems to be OK, I'm then told it's installing, I then get a box saying
Can't install app
Virgin TV anywhere can't be installed . Try again and if the problem continues, get help troubleshooting (link). (error code - 103)
The link makes several suggestions non of which work.
I have managed to find on the web the version I uninstalled to try and cure the problem and this is now working as before but if I try and update it I still get the above error.
Hopefully the next update will cure the problem, at least I can now use the app until then.
