  • 2.43K
  • 16
  • 67
paperclip
Rising star
Message 1 of 5
Mobile Network Settings
On a pay monthly contract is it advisable in Mobile Network Settings to have the following selected?
Preferred Network Type: 4G Preferred WCDMA/GSM
And to have National Roaming selected for data roaming?
I just wondered why I would have 4G selected when Virgin don't use that network for residential customers.
Should I be selecting WCDMA/GSM only? would doing so affect whether I connect to 3.5G?
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 2 of 5
Re: Mobile Network Settings
At the moment you would be better using WCDMA/GSM. That includes 3.5G
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Message 3 of 5
It makes no difference at all it will connect to the best of those options, no need to change
  • 2.43K
  • 16
  • 67
paperclip
Rising star
Message 4 of 5
Thanks for that, what about the national roaming, should I need that changed?
  • 2.18K
  • 242
  • 567
teabag
Problem sorter
Message 5 of 5
As John has advised, leaving it set at 4g will work just fine even though Virgin only have 3g.
Would say national roaming will be the same, if a sim does not support it - it will not use it, so leaving it on will be fine again.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
