Daveby
Mobile Data Connection
Recently purchased Moto G 4th Generation, and acquired a new micro sin from virgin , however mobile data is flaky, i have set up APN correctly I do get 3G symbol followed by H then H+, I believe this is the problem while phone scans for various data protocols. Does any one know of a fix for this?
Apparently previous version  of this phone had a code to force 3G data, which works by all accounts, failing that when is Virgin going 4G?
Helpful Answers
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Re: Mobile Data Connection
Ok firstly 3G is basic H is better H+ is better still and the best currently available on Virgin
Carry out a manual network selection, if you have two options saying Virgin chose the one with the lower case v, if only one select that
All Replies
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Daveby
 JOhn, had two options, one being Virgin Media Mobile Internet which is the one I was using the second was Virgin Media Int both spelt exactly as that , I have just swapped them and seems to be working. I live in hope.
Many Thanks.
