Dicko86
Keep saying call ended
Every time I try make a call it says call ended I can send texts and go online and receive calls but I can't make any cause keeps saying call ended straight awat. I have done a factory reset and still the same issue
  • 7.88K
  • 246
  • 545
Re: Keep saying call ended
Hi Dicko86,
Thanks for your post on the Community Forum and welcome. I'm sorry that you're having a problem with making calls on your mobile. Is this working for you now?
If you are still having a problem with this, please send a private message to me with your name and mobile number, so that I can look into this further for you.
To PM me, simply:
  • Click on my forum name on the left of this post.
  • Go to my profile.
  • On the right had side, select the 'send me a message' option.
Kind Regards,
Terri
Virgin Media Forum Team
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
