IanButler
Is there a problem with mobile data reception in RH11 9JU? Not had anything for 4/5 days.
  • 4.43K
  • 139
  • 333
Moderator
Moderator
Re: Is there a problem with mobile data reception in RH11 9JU? Not had anything for 4/5 days.
Hi IanButler,
Welcome to the community and thanks for posting
Sorry to hear your having issues with mobile data reception.
I've checked your area for you using the postcode you've provided. Coverage is looking healthy on the masts near you with none of the masts currently in fault at the moment.
If you are still experiencing difficulties I would recommend contacting our mobile team on 789 or alternatively on 0345 6000 789 so we can take a further look at this for you.
Speak soon
Stephen_B
Community Moderator
