Xopher1
Is it possible to choose a mobile number?
Hello.
Just wondered if it is possible to select a specific number, if it's not in use elsewhere? I would specifically like the number 07666537147 and I have no idea if there are any numbers beginning 07666.
Does anyone know if there is a way of doing this?
  • 21.46K
  • 759
  • 3.07K
Re: Is it possible to choose a mobile number?
no way of picking mobile number as far as i know
  • 3.84K
  • 902
  • 1.7K
you can't just request a number of your choice. However if you look on eBay there are always lots of mobile numbers for sale. You can purchase it from another network, register it then port the number onto a Virgin SIM card.
AlexKid
