saf_123
Internet roaming problem
Purchased a roaming bundle
Gone abroad and it's not working
Please help
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Re: Internet roaming problem
this forum will not generate a resolution to this no security can't access your account (most of us don't work for virgin)
as you have internet access use the website for the info you need it will show you if its active (you need an account - easy to set up) it can take 24 hours to activate
you may need to call, but check first if its not active you do need to call
