scooby_61
I am having trouble with my virgin mobile signal any ideas
Hi can anyone help or have any ideas i am having trouble with my mobile phone connection i live in Leven Fife ky8 4qe
  • 3.81K
  • 894
  • 1.7K
Re: I am having trouble with my virgin mobile signal any ideas
hi scooby_61,
you don't say whether this is a recent problem, is service normally OK for you?
Checking your post code on the Virgin Mobile Coverage Checker reveals that even ideally your signal strength is only "moderate".
You would be best advised to give Virgin mobile customer services a call on 789 from your Virgin mobile or 0345 6000 789 from any other phone.
They would be able to tell you if there are any known faults or maintenance being carried out in your area which could be affecting you resulting in your poor connection.
If this is the case, hopefully they might also offer a timescale for completion.
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
