Crlnhll
How to fix duplicate text messages to Samsung galaxy ace
Had this problem before - after sending a text message to one of my contacts the handset continuously keeps resending replies that I have received.
Helpful Answers
Crlnhll
Re: How to fix duplicate text messages to Samsung galaxy ace
My Texts are through default text app and yes have noticed consistently low signal on handset.
All Replies
  • 13.7K
  • 561
  • 959
Hey Crlnhll
Welcome to the community, I'm massively sorry to learn about the problems you've been experiencing with your texts lately.
Could you let me know how you send / receive texts, is it through the default text app or are you using a 3rd party application?
Also, are you noticing any signal issues with the handset in general? Consistent low signal for example.
Look forward to hearing from you and getting this sorted
Craig
Crlnhll
Crlnhll
Many thanks - your suggestion worked cheers!
