BenM64
Message 1 of 9
How much does it cost to use data after going over allowance?
Hi there. I've just about managed to over my 1GB data allowance for the month. I was wondering what the charges are like after going over it, if I were to use internet when not connected to wi-fi.
Thanks a lot!
Tags (1)
Helpful Answers
  • 2.4K
  • 262
  • 647
teabag
Problem sorter
Message 4 of 9
Re: How much does it cost to use data after going over allowance?
Each day you use any data it will cost £2 for unlimited data that day.
Example: your allowance has just run out and you have 7 days left untill your refresh date and you use data on all the 7 days = £2 a day for 7 days = £14 extra on your monthly bill.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
All Replies
  • 2.4K
  • 262
  • 647
teabag
Problem sorter
Message 2 of 9
Data after your allowance is used up comes in at £2 for each day you use some data.
Not cheap, so maybe worth you turning data off on your phone untill your next allowance refresh date.
BenM64
Message 3 of 9
So it starts off at £2 whenever I use it and gets higher from there?
  • 2.4K
  • 262
  • 647
teabag
Problem sorter
Message 4 of 9
BenM64
Message 5 of 9
Oh right
Oh right, in fairness that does sound a lot better than I was expecting, though I will go easy on it. Thank you for your help!
  • 2.86K
  • 82
  • 125
Message 6 of 9
Hi BenM64
Welcome to the community Smiley Happy
As teabag advised, you'll be charged £2 per day (for unlimited data use) where any data is used on that day if you exceed your monthly data allowance. This will happen until your next refresh date when your data allowance will be restored.
If you find you go over the 1GB quite often, it may be more economical to switch up to the next plan with more data. You can switch your plan up and down at any time on Virgin Mobile (even if you're in contract with us), but any changes will only take affect from your next refresh date.
To check all the available bundle options, just head to your online account here and select 'Plan and device' and then 'Change tariff'. All the available tariffs will be listed on there for you to choose from.
Let us know how you get on with it.
Many thanks
Mark Y
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
lewis3434
Message 7 of 9
Ok so / I have gone over my allowance waaaaayyyt before it's due to renew (19 days) I've turned off mobile data to avoid charges but work away and really could do with using it.. so - if I buy an add on, can I use the data without being charged the daily rate for being over my original, contracted allowance? Make sense?
  • 2.4K
  • 262
  • 647
teabag
Problem sorter
Message 8 of 9
Hi lewis3434
Yes it makes sense :-)
If you buy a data add-on, while using that add-on there will be NO daily charges, which are now £3@day per 1GB
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
lewis3434
Message 9 of 9
Thanks teabag Smiley Happy and I thought it was £3, was just hoping I was wrong :-p add on being loaded! £10 for 1gb a bit ridiculous in price I feel but it's better than potentially paying £57 extra potentially :-/
