rolandboxall
How do I switch on voicemail on my mobile? It will not invite the caller to leave a message.
How do I switch on voice mail on my mobile? It will not invite the caller to leave a message. It just keeps ringing and then says please try again later.
  • 10.12K
  • 1000
  • 1.87K
Re: How do I switch on voicemail on my mobile? It will not invite the caller to leave a message.
Which provider are you with?
If you are with Virgin, try accessing voicemail. If the service has lapsed, which I find it does occasionally, you will have to ring 222 & go through the setup process again to re-activate it.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
