Kaarreen
Help please
Hi currently on hol in Tenerife phone carrier orange unable to call home or orange customer services. Have pay monthly sim only Virgin contract any advice
  • 3.84K
  • 902
  • 1.7K
Re: Help please
Hi Kaarreen,
it sounds like International call barring may be on in your account.
 Log in here: Your Account > click on  the "Plan and device" tab.
Go to "Manage my services" > check that "Roaming" is set to ON & "International call barring" needs to be set to OFF
If you have to change these settings. Allow time for your account to update then reboot your phone by turning it off & on again.
Hopefully this may be your problem and you'll soon have it sorted.
If not, you could try here for help: Help and Support - Contact Us > Mobile > Mobile not working > Chat online.
The advisors are often busy though so you may not get connected straight away.
Alternatively, if you can borrow a phone to call Virgin Mobile. Their UK support line number is: +447953 967 967
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
