Confused45
Just joined
Help international texts
Can anyone help.
Is there a add on to reduce the cost of sending international text messages. There has to be a cheaper way than 30p each text. Thank you
Helpful Answers
  • 17.83K
  • 1.67K
  • 3.13K
Re: Help international texts
There isn't an add on, but the cheapest way to send messages internationally would be via an app such as WhatsApp.
Appreciate this is reliant on both people having a compatible Smartphone and a data connection, but there isn't then a per-message cost. Any costs are built into any existing data plan.
All Replies
  • 17.83K
  • 1.67K
  • 3.13K
