  • 16
  • 13
Forum Team (Retired) MichaelGr
Message 1 of 1
HELP GUIDE - Mobile Data Roaming for Pay Monthly / SIMO Customers
If you are having problems using mobile data whilst you are abroad and your calls and texts are working fine then please try some of these diagnostics as they may help you connect whilst you are away. Hope this works for you. Have a nice trip.
In the first instance, please see our online Help & Support pages:
Going abroad with Virgin Mobile
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
Roaming Costs
Using your Virgin Mobile abroad FAQs
Please ensure Data & Data Roaming options are turned ‘ON’ in your device settings. Here are the basic steps for most devices:
Most Android devices – Settings > More Networks/Settings (you may skip this step on recent android devices) > Mobile Networks > Ensure Data Roaming is turned ‘ON’.
Most IPhone’s – Settings > Mobile Data > Ensure Mobile Data and Data Roaming are turn ‘ON’. Please make sure EU Internet is turned ‘OFF’.
If you need exact instructions please post the make and model of your device.
Please check that roaming is activated in your online account (Please allow 24 hours for changes to complete):
Online account > Plan and device > Manage services > Going abroad
Please check that the APN selected in your account is displayed as Virgin and not another network provider. Here are the basic steps for most android devices:
Settings > More Networks/Settings (you may skip this step on recent android devices) > Mobile Networks > Access Point Names = Virgin Media Mobile Internet
** It is not possible to manually change APN setting on IPhone’s but you can still reset the APN settings. Please note this will also reset the Wi-Fi networks so you will need to re-key your wireless passwords. Settings > General > Reset > Reset Network Settings.
If there is no option for Virgin APN’s then you will need to add them manually. Visit this link to get yours:
Online Send Phone Settings: https://virgin.wdsglobal.com/phonefirst?captchaEnabled=true&contractId=289&networkId=84&countryId=36...
[MOD EDIT: Above link changed as old link no longer works]
Alternatively, you can try these APN settings:
Name — Virgin Media Mobile Internet
APN — goto.virginmobile.uk
Proxy — Not Set
Port — Not Set
Username — user
Password — Not Set
Server — Not Set
MMSC — http://mms.virginmobile.co.uk:8002
MMS proxy — 193.030.166.002
MMS port — 8080
MCC — 234
MNC — 30
Authentication type — PAP
Thanks for reading
Mike
I work for Virgin Media Mobile however my posts are my own opinions and Virgin cannot be held responsible.
