eds89
GSM Codes to enable forwarding to voicemail
Can anyone advise the GSM codes to enable call forwarding to my voicemail?
My Lumia 640XL does not seem to have anything built into the GUI to manage this.
Many thanks.
eds
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Re: GSM Codes to enable forwarding to voicemail
No and virgin does not support call forwarding sadly
eds89
I did speak to a guy in tech initially, and he did the normal reset of voicemail, then gave me the GSM codes to turn on forward to voicemail.
It was something along the lines of ##67#+447(rest of some mailbox number)#
Then also did ##61#+447xxxxxx#, and ##62#+447xxxxxxx#
I don't remember what the number was, and didn't record it. Was hoping someone might know what it is, save me another call to them?
  • 6.83K
  • 217
  • 508
Hi eds,
Thanks for your post on the Forum. the number you are referring to should be your own voicemail box number.
To obtain your voicemail number. Dial *#67# from your phone. The number will then be displayed on their screen.
Check out our online Help pages for more information about your voicemail service:
Voicemail FAQs.
Many thanks,
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
