  • 7
calaf01
Difference between Using the Internet using WIFI and using 3G
How can I tell the difference on my bill between Using the Internet using Wifi which doesn't use up my data allowance and using 3G which does?
Helpful Answers
  • 62
  • 7
ericos
Dialled in
Re: Difference between Using the Internet using WIFI and using 3G
I would presume internet/data using wifi doesnt show on your bill.
All Replies
  • 62
  • 7
ericos
Dialled in
  • 7
calaf01
I don't know. All it says is Using the Internet. It doesn't specify whether it's via Wifi or 3G. If you tell me that Wifi access doesn't appear on the bill I'll believe you. There is some sense in that, though some measure of my internet use using Wifi would  be useful in itself.
  • 62
  • 7
ericos
Dialled in
Doesnt the  phone have a facility to measure data transfer & say whether it is wifi or phone traffic?, I'm pretty sure my current (Nokia Lumia 7350 & previous (Huawei) did.
  • 7
calaf01
Thank you. I know at the time I'm using it which one I'm using, but I was looking for a summary of bytes used on each one on my monthly bill.
  • 1.58K
  • 101
  • 270
You'll need to use an app on your handset to separate wifi and 3G usage figures. Your bill only shows data usage that Virgin Mobile are aware of, which is 3G only.
