devonred
Data roaming failing - APN?
Afternoon all,
I have a Fairphone with a VM sim (although my display reads T-mobile). I have no problems making calls overseas but the phone won't make a 3g connection (offhand I can't remember about texts). I wonder whether it's a problem with the APN?
Any ideas?
The current default details are:
APN: general.t-mobile.uk
APN type: not set
Proxy: Not set
Port: Not set
Username: t-mobile
Password: **
Server: *
MMSC: http://mmsc.t-mobile.co.uk:8002
MMS proxy: 149.254.201.135
MCC: 234
MNC: 30
Auth type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4/IPv6
APN enable/disable: APN enabled
Bearer: Unspecified
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Re: Data roaming failing - APN?
These are the ones for Virgin.
However have you bought a data Travel Pass. You will need one to get online
Name — Virgin Media Mobile Internet
APN — goto.virginmobile.uk
Proxy — Not Set
Port — Not Set
Username — user
Password — Not Set
Server — Not Set
MMS proxy — 193.030.166.002
MMS port — 8080
MCC — 234
MNC — 30
Authentication type — PAP
APN type — internet + mms
devonred
Hey enlli,
Thank you! Yes I had a travel pass and was all set (or so I thought..) I'll give the settings a whirl
