  • 48
Dal
Message 1 of 5
Data Usage Help
Hi All
Can i get some advice please.  I have somehow managed to use up all of my data usage.  I have looked on my account details and i can see that a couple of days ago around 25 mins past each hour my phone started using between 35mb - 38mb.  I have turned off my data roaming but is there any way i can see which app would of been causing this to happen
Helpful Answers
  • 11
Smellytears
Message 2 of 5
Re: Data Usage Help
Dal wrote:
Hi All
Hello there,
Best bet would be to download an app called "My Data Manager". You can set that up, include how much data you're allowed per month (or if it's unlimited or not), set up the plan cycle dates, and the app will then inform you of how much data you're using - as well as what apps consume what data.
You can even set it up so that data is disabled after a certain usage.
Hope that helps
Smellytears
All Replies
  • 11
Smellytears
Message 2 of 5
Re: Data Usage Help
Dal wrote:
Hi All
Hello there,
Hope that helps
Smellytears
Petefoz
Message 3 of 5
Re: Data Usage Help
thanks for the suggestion but I already have my data manager.  It reports the biggest download is os services.  Is there anything I can do to cut that back?
When I could look at usage, it was at the same number of minutes past the hour, usually overnight, only a couple of Mb each time but for several consecutive hours.  Some nights it used enough power to flatten an almost full battery.  Does any of this help find out what is going on and what to do to stop it?
  • 8.26K
  • 236
  • 340
Forum Team (Retired) Mat_H
Message 4 of 5
Re: Data Usage Help
Hi Petefoz,
I've replied to your other thread for this Smiley Happy
Mat
Lucykeywood
Message 5 of 5
Re: Data Usage Help
I have the app, how do you make is so data is turned off after a certain point
Tags (1)
