oporus
Just joined
Connection charge of £1 when data roaming turned OFF
I have data roaming turned OFF permanently on my phone but I keep getting a £1 connection charge for small amounts of data on odd days. I have a data usage app that shows amounts of data used on WIFI and cellular separately. Data shown in cellular is zero as I would expect. So what are these charges about ?
26 Dec 12:06Using the internet Yes940 KB£0.00
26 Dec 11:11Using the internet No264 KB£1.00
18 Dec 10:37Using the internet No75 KB£1.00
10 Dec 09:01Using the internet No59 KB£1.00
07 Dec 10:27Using the internet No4 KB£1.00
  • 1.55K
  • 195
  • 391
enlli
Super solver
Re: Connection charge of £1 when data roaming turned OFF
When you say you have Data Roaming switched off are you in the UK or abroad. It will make no difference in the UK as you need to disable Cellular Data.
Small amounts of data can be used when Wifi goes to sleep to conserve battery, especially overnight.
  • 209
  • 6
  • 19
Hi oporus,
Welcome to the community and thanks for posting!
What @enlli has posted is correct in that data roaming will only ensure the handset does not connect to data when roaming abroad.
Have a look for a setting for mobile data or data services and turn that off. This will stop those £1 charges appearing
Let us know how you are getting on.
Liam_T
