Bow-cage
Can now when abroad use my own mobile to ring home
I have registered on line with new log in deatails can I now when abroad use my mobile to ring home?
some people can not it would seem, why is that please?
  • 7.24K
  • 810
  • 3.04K
Re: Can now when abroad use my own mobile to ring home
Yes, of course you can -  provided you have enabled roaming. See these FAQs for more information and what you have to do. Click on the link.
http://help.virginmedia.com/system/selfservice.controller?CMD=BROWSE_TOPIC&SELECTED_BROWSE_TAB=porta...=
You can also use SmartCall on your mobile if you have a VM fixed line and call package and are connected to WiFi
Check that out here
http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=45486&CURRENT_...
Is this anything to do with your other question over which I puzzled and I have still no idea what it means.
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
