  • 71
  • 8
rodbrown1949
Dialled in
Can I use my VM minutes while using Skype?
I have an unlimited tariff  for minutes and texts per mon with VM. I hardly use either of them to that extend, so I was wondering if could somehow use these when I'm on Skype, even though it is a different app to my current phone & text apps?
Appreciate any help you can give.
Helpful Answers
  • 21.76K
  • 797
  • 3.13K
Re: Can I use my VM minutes while using Skype?
no you can't Skype uses the data connection not the mobile voice network
All Replies
  • 21.76K
  • 797
  • 3.13K
  • 71
  • 8
rodbrown1949
Dialled in
Thanks,  for the info
