nemuritorul
Just joined
Message 1 of 7
Call forwarding
Hi there.
Is it possible to set up call forwarding to my softphone or straight to my other mobile out of UK and also get unlimited calls to 0845/0875 and 03 numbers?
Thanx for reply.
  • 3.82K
  • 897
  • 1.7K
Message 2 of 7
Re: Call forwarding
Hi nemuritorul,
I'm afraid Virgin Mobile don't do call forwarding Smiley Sad
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 3 of 7
Re: Call forwarding
Sorry no call forwarding. Smiley Mad
nemuritorul
Just joined
Message 4 of 7
Re: Call forwarding
Thanx for the answer. How about 0870 and 0845 numbers, what is the minimum plan to got unlimited calls to these numbers?
  • 3.82K
  • 897
  • 1.7K
Message 5 of 7
Re: Call forwarding
Hi again,
here you go: SIM only deals
AlexKid :-)
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 6 of 7
Re: Call forwarding
While the cost of calling some of these numbers can be just a few pence, others can cost significantly more, and it can sometimes be difficult to find out exactly how much you’re being charged.
To make it clearer how you're being charged for these calls, the cost is split into two charges: the Access Charge and the Service Charge. You’ll then be able to calculate the total cost calling these numbers by adding together the following two charges:
  • The Access Charge - this is what Virgin will charge you per minute for making the call
  • The Service Charge - this is the rest of the call charge, which will vary based on the organisation you’re calling, who must let you know how much this charge is. For example, if the Service Charge was 20p per minute, the organisation you are calling might say: “Calls cost 20p per minute, plus your phone company’s Access Charge”. Depending on the number, the Service Charge may also include a connection charge.
Even if Virgin were to make the access charge inclusive to your tariff there would still be the service charge to be collected.
I use this as much as I can http://www.saynoto0870.com/
  • 3.82K
  • 897
  • 1.7K
Message 7 of 7
Re: Call forwarding
here are Virgin's call plans on a pay monthly tariff. It includes calls to 084 and 087 numbers: SIM Only Deals
AlexKid :-)
