E1len
Message 1 of 8
Call and text logs not working since switching to virgin
I recently change from giffgaff to Virgin, my phone now will not send texts and I can't view texts I have received. Also it does not log texts or calls, taken or missed,
Can someone advise if there are settings I need to change.
  • 3.84K
  • 902
  • 1.7K
Message 2 of 8
Re: Call and text logs not working since switching to virgin
Hi E1len,
if you click on the link here: Phone Settings you should be able to select your handset. Click on the link, follow the instruction & you'll receive the correct settings on your phone.
Hopefully this sorts things out for you Smiley Happy
AlexKid :-)
If you want to say thanks > click 'Kudos'.
If this has helped answer your question > click 'Helpful Answer' also.
E1len
Message 3 of 8
I did that is only gives settings for Internet, picture messaging (which I don't want) and something else (nothing to do with text or calls).
Thanks though.
  • 461
  • 56
  • 79
Lee_B
Fibre optic
Message 4 of 8
Hi E1len
It wont be the Virgin network that is the issue has its not the sim that records the data , this is the handset.
What handset do you have?
Have I answered your question today? Mark the question as resolved if so!
Mark as helpful answer if this has helped you to show other members the resolution
Virgin Mobile Staff , However, All opinions are my own
E1len
Message 5 of 8
Hi it's Samsung GT-S5830i, I've tried downloading the messaging configuration but that hasn't worked.
Many thanks
  • 3.84K
  • 902
  • 1.7K
Message 6 of 8
Hi E1len,
is this your phone:
I looked here : Phone Support
Is the service centre number correct?
I'm afraid I can't offer any further ideas. As Lee said it may be a fault with your phone rather than the settings and I am sure he is much more knowledgeable about such things than myself.
Let us know how you get on.
Good luck,
AlexKid :-)
E1len
Message 7 of 8
Hi yh the call centre number is correct, I have no idea what's going on with it now?? I've tried everything I can think of.
It was working fine before I switched??
  • 3.84K
  • 902
  • 1.7K
Message 8 of 8
Hi E1len,
have you tried taking the battery out whilst the phone is on, then replace it and turn your phone back on ( this will force the phone to reboot which often helps).
From the same link I used earlier: Phone Support there is more suggestions of help.
One idea which may well work would be to perform a reset on your phone (the instructions are there in the Phone Support) the only problem with doing this is that it will wipe your phone (not your SIM or memory card).
If you decide to try this therefore make sure you back up anything that you wish to save.
Keep us posted, good luck,
AlexKid :-)
Answered your question? > click 'Mark as Helpful Answer' also.
