  • 112
JohnWB
Best way to measure Data daily usage
Does anyone have any recomendations as to what is the best way to measure Data daily usage on an iPhone
  • 111
  • 5
  • 26
Re: Best way to measure Data daily usage
Hi JohnWB,
Thanks for posting about you data usage. So I can give you the best recommendation I would like to ask a few more questions.
Are you just trying to view what app uses what amounts of data or are you looking to restrict apps using mobile data?
What software version are you currently running on the Iphone?
It may be worth having a read of the Geek Squad's guide on how to monitor your data usage
If you would like more assistant just let me know.
Mike
