  • 6
katrina52
Message 1 of 12
TIVO installation problem - connection not found - pls help?
So not doing well here - called for Activation
Started - but at the 'Installing Software' screen it says
Connecting - Service not found.
I know Broadband is working fine - I've connected the white cable from the wall into the TIVO box, but does it make a difference that the hub is upstairs?
I telephoned but the lady said it takes up to an hour - well it's been 20 mins plus that now.
Can anyone help please?
Hugeboot
Message 2 of 12
Re: TIVO installation problem - connection not found - pls help?
I'm having the exact same issue? Did you get a solution?
  • 6
katrina52
Message 3 of 12
Not resolved here - phoned again and they said their engineers are working flat-out to resolve the problem.  He re-sent activation signal - but still no joy.  Looks like there'll be no TV watching for me tonight.
  • 6
katrina52
Message 4 of 12
Still no connection - service not found.
Does it make any difference that the HUB is upstairs?
justme3
Message 5 of 12
no,it makes no difference,my hub is in the same room and i have same problem.they sending someone out on friday to sort it
  • 6
katrina52
Message 6 of 12
Just a quick update:
Phoned again literally 5 mins ago and they have a fix that worked for my unit over the phone.
Whoop whoop!  Well done VM Team - great customer service lady.  Thanks.
ktbean
Message 7 of 12
I don't suppose the lady on the phone told what the fix was? I'm having the same problem myself!
petemarshall33
Message 8 of 12
Having the very same problem. Just moved home and have new superhub and TiVo box to self-install. Broadband is working fine but TiVo box can't get past the "connecting" stage of the software install, just keeps saying "service not found". Help!!!
  • 16
Toghraee
Message 9 of 12
Turn the tivo off.
Press 'Tv' , 'channel down' , 'record' buttons on the tivo together without removing your fingers turn on the tivo.
Remove your fingers after a minute. Wait till software installation pass.
petemarshall33
Message 10 of 12
Thanks TMW. I'll give that a try
