Settled in nicely II
Little-croc
Best speed testing website
As the title says what's the best speed testing website I have always used speedtest.net but bloke at virgin told me speedtest.bbmax.co.uk is better at the latter it tells me my download speed is 95mb which I'm happy with but at speedtest I'm only getting 30mb unless I mess around choosing different servers but I always thought speedtest.net was meant to be the most reliable one maybe the virgin bloke gave me one which favours virgin lol On another note experiencing problems with ps3 through the super hub wired connection only getting 30mb download speed & when I'm actually downloading for one demo it could be quick for another extremely slow any reply appreciated. Thanks
Please use plain text.
Tech Wizard II
adacom
Re: Best speed testing website
[ Edited ]
speedtest.net is a front end to all the servers - they can be anywhere and any standard - london namesco or paris is usually reliable - but even they can give differing results - depends how many people are accessing at one time for example
http://www.speedtester.bt.com/beta/speedtest-remote.jsp
thats another one - i think its the same server as speedtest london namesco - but can again give different results
____________________
Tony
Little-croc
Thanks mate
Tech Wizard I
Stythinator
[ Edited ]
Hiya,
I agree with Adacom here. The one he suggested is rather good.
Tech Wizard II
adacom
Stythinator wrote:
Hiya,
thanks for agreeing with me - but why bother :smileyfrustrated:
Tony
Tech Wizard I
Stythinator
Because i responded to reasure Little-croc that the one you mentioned was good. Dont like it? tuff :smileyvery-happy:
Tech Wizard II
adacom
many thanks for the recommendation - why should the OP need reassurance?? - i dont see the point of it apart from it increases your post count - which seems to be the object imo
Tony
Pro II
swt4ajp
i dont recommend speedtest sites as most of them seem over used at the times of being used
i just recommend using something like this
Click Here to download a test file please click it twice and after about 1 minute calculate the speed together
thats a better speedtest then any of the speedtest websites
I do not work for Virgin Media, All advice is given at your own risk. Im A Computer Tech/Network Engineer If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Helpful Answer. | Connection Problems Check Here | Forum changes | Blackburnnet | Broadband Wiki |R36 Release Notes | GamesUnited | How to Test Your Speed | Blackburnnet on Facebook | GamesUnited on Twitter
Tech Wizard II
adacom
i am coming round to that way of thinking - even the ones VM point to - london namesco and paris on speedtest.net have been poor this last week or so - they are a guide and no more
Tony
A regular I
monaro800
A good way to bench your network is with ISP Test files, Leaseweb has 100mb 1000mb and 10,000mb test files on europes largest network 2.3TBPS capacity.
I find it to be very reliable
http://www.leaseweb.com/en/help/all-about/hosting-network
R
M Shirley
DISCLAIMER:
I do not work for Virgin, nor would i ever.
VM SuperHub Modem Only Mode
HP Procurve 10/100/1000 24 Port Managed Switch
TP Link Turbo N+ Wireless Router
Watchguard Firewall
Wired Total :-: 9 Wired Devices
Wireless Total :-: 6 Phones, 2 Tablets
