Ask a question
Fresh as a Daisy
Tivo box doesn't work
Hi.
I came back from holiday and turned my tivo box on and for some reason it starts preparing channel information and freezes on 25%. My card is in correctly. Anyone any ideas please?
Many thanks!
Re: Tivo box doesn't work
Hi andybfc,
I think the first error was turning it off to start with! :smileywink:
It doesn't sound good, so I'd suggest giving 151 a ring.
Loc: PR4 1, TV: XL+SkyHD, BB: 100Mbps
2x 1TB TiVo: {15.3.1.RC3-VMC-2-C00}
SuperHub: R37 {Modem mode}
I don't work for VM, and I don't plan to!
Please use the Search feature before starting a new thread (or if you're feeling brave, RTFM! :smileywink:)
To thank or if you Like a post, use the Kudos + button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
try booting it without the card in, then insert the card
