Ask a question
Bright Spark
Tivo box and my home network
Hi we got a new tivo box fitted a few days ago, i was wondering if its possible to conect tivo to my home network via a cable to my router. The engineer said that it may be possible but i have tried to no avail
Re: Tivo box and my home network
It is possible to connect it to your home network, but what are you expecting to be able to do once you've done so?
Brainbox
This should work.
THe only things you can currently do with it connected to the network is Remote Control from a device such as android phones (using Tivo Commander) and iPads/iPhones (using Peanut app).
YOu have to enable this in the settings mind you.
Bright Spark
I was wondering if its possible to stream films of my pc to the tivo box.
The Troubleshooter
[ Edited ]
No it is not possible.
That is what a Lovefilm app and/or Netflix app on TiVo will be for when ever it comes out.
________________________________________________________________________________
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer.
Good to Know
i use a tivo remote on my windows vista laptop
http://community.virginmedia.com/t5/TiVo/VM-Tivo-Net-Remote-for-PC-running-Windows-7/td-p/862523/pag...
this post may contain nuts Smiley Wink
Good to Know
new link and tested on my home network. it works. with vista 32b and 64b.
http://www.andypwheeler.pwp.blueyonder.co.uk/tivoremote/
Ver 0.03
 sometimes the superhub will kick it off but just switch your wifi card of the on again.
Have fun.
One to Watch
not possible mate, VM need to enable the Tivotogo service, like U.S users have, (which they have no plans to do when i rang them yesterday) - Until they do this, no streaming media.  It's very disappointing.
Making Waves
I would like to access shared files on my PC from my TiVo box. Is that possible?
Also, does the Tivo box need to be connected via Ethernet to my home network to enable android app controlling?
You cannot share files from the tivo to a pc, you need to network the tivo to allow apps to work as a remote control
