Ask a question
Making Waves
TiVo HD Poor quality HD - NOT HD
My TiVO HD box is not displaying an HD picture - simple! HD cable is in, tested signal etc and all good there but the picture is just poor.
Anyone know of anything else I can check?
Mythical
Re: TiVo HD Poor quality HD - NOT HD
You can check the video output is 1080 and you have removec the scart
Making Waves
Sorry, forgot to mention I'd tried that before and also tried removing the cable and trying a different one also.
Captain Clued-Up
As someone pointed out to me recently, just because you're watching an HD channel doesn't mean that the programme is in HD. Look for the HD indicator in the info for the programme.
Sony Bravia TV, Sony home theatre, Sony Blu-ray, Humax PVR, TalkTalk broadband
Making Waves
Yes thanks, I understand that. It's noticeable when watching something in HD on the HD channels.
Making Waves
Also for example the BBC HD preview channel should be previewing in HD should it not? It isn't HD!
Specialist
As someone else mentioned, check the Output settings and re-run the auto check.
Never had any issues when things are set to auto.
Hi tjchittz,
If you've come from a V+HD box, you'll find that TiVo actually renders a sharper picture.
As with any new device, you may need to tweak the settings on your TV to ensure the best viewing experience.
Assuming you have a full HD TV, have you confirmed that TiVo is set to output 1080i only?
Loc: PR4 1, TV: XL+SkyHD, BB: 100Mbps
2x 1TB TiVo: {15.3.1.RC3-VMC-2-C00}
SuperHub: R37 {Modem mode}
I don't work for VM, and I don't plan to!
Please use the Search feature before starting a new thread (or if you're feeling brave, RTFM! :smileywink:)
To thank or if you Like a post, use the Kudos + button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
Making Waves
Hi thanks for your replies.
Yes, the TV is set to 1080i. I've run the test, tried manually selecting 1080i and then also let TiVo automaticallly detect that this is the correct setting for it so that's fine.
I've tried a different HD cable other than the one supplied and that makes no difference.
Also tried the usual things off making sure the cables are all fitted correctly etc.
It's odd that the Homescreen is crisp, sharp HD but then the picture isn't? Also, I'm not at my tv now so can't check but I'm pretty sure that the info guide (smaller info bar that appears in fullscreen) is NOT in HD on HD channels and is the same grainy picture.
The picture is upscaled from SD on HD channels but the HD programmes are not HD!! Please, if anyone has any other suggestions, please feel free to post. Anyone from Virgin out there!?
That definitely doesn't sound correct!
It could be a signal level issue, but then that shouldn't affect the mini-guide as it's rendered by the box itself.
