Ask a question
Fresh as a Daisy
How to connect Tivo and home cinema
I have a Sony KDL 37W5700 (4 HDMI and 1 optical out) and have just bought a Sony BVDE280 bluray home cinema system (2HDMI in, 1 out, 1 x optical in).  How do I connect this up with my Tivo box to get surrond sound while watching TV?
Captain Clued-Up
Re: How to connect Tivo and home cinema
Assuming the KDL is a TV, I'd guess an HDMI cable from TiVo to Blu-Ray (in), then HDMI (out) from Blu-Ray to TV.
Sony Bravia TV, Sony home theatre, Sony Blu-ray, Humax PVR, TalkTalk broadband
Fresh as a Daisy
Thansk for a quick reply, the KDL is a TV.  Do you know if I will need to connect an optical cable from the TV to the home cinema system or from the Tivo box to the home cinema system?
Good to Know
Mine is connected optical out from tivo to home cinema
Captain Clued-Up
I just use 2 HDMI cables to connect my Tivo - Home Cinema - TV.
_____________________________________________________________________________
1TB TiVo, 500GB TiVo, V+,
XL TV, 120MB BB, M Phone
If you like my post or want to thank me, click on the Kudos Star or Mark my answer as helpful
Fresh as a Daisy
I will connect by HDMI and optical from the tivo to the home cinema and then by HDMI from the home cinema (out) to the tv.  Thanks for your comments
Crafty
No need for the optical cable
HDMI from tivo to home cinema in.
hdmi out of cinema  to TV
Fresh as a Daisy
I have connected using 2 HDMI's and it is working great.  Thanks for the advice
Good to Know
That means you have to have the home cinema on all the time!
Captain Clued-Up
I do, as thats how I listen to any audio from the TiVo/PS3/Bluray player
