  • 635
  • 21
  • 127
MrHalfAsleep
Rising star
Message 1 of 5
Yet another speed test site (may be useful)
This one gives all sorts of info and you can do repeat (auto) tests over a (user set) period of time.  It utilises servers in London, so you might get a better result down there.  It also gives quite comprehensive results:
:::.. Download Speed Test Result Details ..:::
Download Connection Speed:: 72593 Kbps or 72.6 Mbps
Download Speed Test Size:: 46.4 MB or 47488 kB or 48627712 bytes
Download Binary File Transfer Speed:: 9074 kB/s or 9.1 MB/s
Tested At:: http://TestMy.net  Version 15
Validation:: http://testmy.net/db/kUC0hGNfH
TiP Measurement Summary:: Min 35.02 Mbps | Middle Avg 100.61 Mbps | Max 360.12 Mbps | 165% Variance
TiP Data Points:: 55.27 Mbps, 35.3 Mbps, 74.9 Mbps, 360.12 Mbps, 356.52 Mbps, 64.47 Mbps, 64.35 Mbps, 74.27 Mbps, 74.43 Mbps, 42.09 Mbps, 35.02 Mbps, 41.99 Mbps, 52.51 Mbps, 70.04 Mbps, 69.77 Mbps, 61.68 Mbps, 61.57 Mbps, 171.4 Mbps, 115.75 Mbps
<edit>
Test Time:: 2016-12-15 18:18:28 Local Time
<edit>
Target:: London, GB http://uk.testmy.net
Client Host:: Virgin Media http://testmy.net/hoststats/virgin_media
Compare:: 50% faster than client avg, 78% faster than host avg, 222% faster than city avg, 230% faster than country avg, 231% faster than world index
1MB Download in 0.11 Seconds - 1GB Download in ~2 Minutes - 1296X faster than 56K
This test of exactly 47488 kB took 5.363 seconds to complete
<edit>
http://testmy.net/
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
  • 2.96K
  • 378
  • 939
Message 2 of 5
Re: Yet another speed test site (may be useful)
I have been recommending the multi threaded test (http://testmy.net/multithread) on that site to PS4 users on here for a while now as it is one of the few test sites that runs OK in the PS4's web browser.
______________________
Scott
  • 635
  • 21
  • 127
MrHalfAsleep
Rising star
Message 3 of 5
I stumbled across it by searching the Googles and thought it was worth a go, as it seems to be different to the usual speedo format testers.  I also noticed a few VM readings as well, meaning users here got there before I did.Smiley Happy
  • 14
Forgotten
Message 4 of 5
<edit>
<edit>
<edit>
http://testmy.net/
Ever want a test that is 100% reliable and actually use there own servers there is always HTTP://OVH.NET <3
Also as http://speedtest.net is going a little downhill they seem to be doing alright with http://beta.speedtest.net
"I have not failed. I've just found 10,000 ways that won't work." - How everyone in a technical field should think.
  • 362
  • 15
  • 83
pyrotenax
Fibre optic
Message 5 of 5
Excellent , thanks for the headsup Smiley Happy
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
