  • 14.43K
  • 1.14K
  • 2.75K
Message 1 of 4 (73 Views)
Word 2016 comment issue
time for me to pose a question Smiley Happy, got a strange issue on word when adding comments sometimes comments appear with small bar example:
but some appear big bar example:
large barlarge bar
and some appear with small bar
small barsmall bar
anybody got any ideas on how to make all the big bars, appear the same as the small bar
  • 7.42K
  • 453
  • 1.96K
Message 2 of 4 (62 Views)
Re: Word 2016 comment issue
Isn't it the format of the comment?
Where its split over two lines=big bar
on one line=small bar?
  • 14.43K
  • 1.14K
  • 2.75K
Message 3 of 4 (60 Views)
[ Edited ]
the format of the comment is the same in both big and small.. its the bar is size is some how doubling, the comment itself should fit on 1 line, even if i don't have any text in the comment the bar is double..
*edit*
just to add if i remove all personal info, so the comment creator becomes author does the exact same double bar, if choose to resolve on the double bar it becomes single bar the way i want, but the text becomes light grey colour
  • 14.43K
  • 1.14K
  • 2.75K
Message 4 of 4 (28 Views)
tried via Word 2010 and a lovely single bar.. Smiley Happy
