Fluffy77
Settling in
How to block nussence calls
I need to block two phone numbers. A person is harassing us. I will be going to the police if blocking a phone number isn't possible.
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Re: How to block nussence calls
Have you seen this
How do I stop unwanted, nuisance, malicious or withheld-number calls?
Do you have caller display?
Personally I use a phone that allows me to block any numbers I want and filters unsolicited calls etc.
  • 4.01K
  • 202
  • 898
cybmole
Community elder
like the man said - buy a phone that can do call blocking. most can, don't cost much. they all need caller ID to work from. you can then also block caller withheld calls to prevent that workaround - we send those direct to answer machine.
what do you expect the police to do - have Mr Plod take your calls for you?
